Hello, I hope are well. Good buy your updater drivers because I've had problems with the controller coprocessor tells me that I have no driver installed this happened to me with windows 8 and now you install Windows 10 I still have the same problem coupled now that I do not recognize the camera or I only detects a microphone you connect a camcorder screen and the same. I open the AVG Driver Updater scan my machine and I make all my drivers are updated and installed which is not true therefore the truth is I am not satisfied with the service of AVG Driver Updater instead the AVG Ultimate I have no complaint. And I hope they can correct these mistakes mentioned above. Beforehand I thank you
Hello Roberto,
Were you using AVG Driver updater when you had the Windows 8 Operating System?
Hello Roberto,
