Problems with AVG on system startup on on trying to uninstall/remove the program
Hello Chris,
May I know the name of AVG program that is installed on your PC? Is it free, trial or paid version?
Could you please check on C:\ drive whether any folder present as AVG remover, if yes, please delete it manually and check whether you are getting the error again.
Everytime my computer starts up I get an error message from avgui.exe . it says "The exception Illegal Instruction. An attempt was made to execute an Illegal Instruction. (0xc000001d) occurred in the application at location 0x621447ad." When I try to remove AVG I also get an error message saying that 'zstatetoolx.exe has stopped working', and 'AVG Remover Utility has stopped working', and then I get an error message saying 'None has stopped working'. Please can somebody tell me why am I having this problem with AVG and how do I fix this?? Also when I try to uninstall AVG from the Control Panel it doesn't work. Please help!?
Thank you for informing that you are using the free version of AVG.
We are sorry to know that you couldn't remove the files of AVG.
In this case, we request you to send us the log files of AVG for which we have sent you the email instructions.
Please check for the email on spam or junk folders if the email is not present in the inbox.
Chris, we apologize for the inconvenience caused.
This isn't a virus, this should be some issue with the application.
We have sent you the email instructions to get our additional support so that they can collect the log files and escalate your case to our level two technical team.
I have just tried this but I get the same errors when running the removal tool, even in safe mode. I get these crash errors all the time : 'zstatetoolx.exe has stopped working', 'AVG Remover Utility has stopped working', and 'None has stopped working'. then when I restart into normal Windows the original problem is still there!! AVG isn't removing properly, cannot be run properly and cannot be removed properly. is this a virus??
