Problems with AVG Remover / Installation being corrupt
Hello Kevin,
We apologize for the difficulties you are currently experiencing.
We appreciate your valuable effort in trying to fix the issue. I have sent you an email with further instructions to be followed to get our additional support. Please check for the email on spam or junk folders if it is not present in the inbox.
Hello,
I recently had a problem with AVG not updating so I attempted to remove it using the removal tool so that I could reinstall the most updated version.  I had left my PC on overnight and the removal tool had not completed yet. I thought that it was stuck so I attempted a few more times and got the same results of the removal tool not removing all files.
I then attempted to just intall the latest version and when I attempt to update it says" The update has not been finished because the installation is corrupt"
What can I do to remediate this issue?
I have Windows 10 and the free version of AVG right now.
Hello Kevin,
