Hi Trevor,
Thank you for contacting AVG Community Support. I see you are facing issues with AVG TuneUp. I am sorry for the inconvenience. Could you please share us the screenshot of the page (https://support.avg.com/SupportArticleView?urlname=AVG-Create-screenshot)?
Hi Trevor,
When my AVG Tune Up completes it always deletes my saved passwords. Does anyone have a solution to this other than what I have to do now which is avoid using AVG Tune Up
Thank you for writing back to us, Trevor.
We regret the inconvenience this has caused you.
Once a TuneUp scan is done, the program will display scan results (junk files/broken registries/browser data found).
Please uncheck "Browser cache", "Tracking & other cookies" under the scan results and check if the issue persists.
Keep us updated.
Didn't really make much difference. I've now uninstalled AVG Tune Up and surprised at, ironically, how much more tuned up my PC is and is operating much more smoothly. Needless to say I won't be renewing when my current subscription ends. I will be looking for something less cumbersome
If I run AVG Tune Up in all of its sections my saved passwords get deleted and I then have to go back and re-do them. Very very frustrating so I have stopped using AVG Tune UP
