Hello Randy,
I am sorry for the inconvenience. Please check if you have installed the latest version of AVG Program in your computer. If possible please share the screenshot http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot of AVG PC Tuneup interface to assist you further.
I just purchased another AVG tuneup but i am finding it difficult to update or to reinstall because it does not appear whenever i click on it and i am confused.The instruction says i should,
Open AVG product and go to AVG Dashboard,
Open the connect menu and click on 'Connect",
Log in with my password and email,but i am getting confused because i don't know where to start.
The first time was easy because i used a licence number but not this time
Hello Randy,
Randy, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
