Hi Alan,
We're glad to help you with this.
Sometimes, you might receive the error if the program on your computer is unable to communicate with our server.
Regarding the blank screen, this isn't the usual behavior of Secure VPN.
In this regard, please restart your computer once & check if it helps. If it fails, we may need to reinstall the program.
In stalled AVG Secure VPN but cannot access it. It says it is installed and activated but when I click on the icon all I get is a white screen. I also got an error message saying there is a technical error but does not give me specifics. What should I do?
Hi Alan,
