Problems with password protection
Hi Jonathan,
This isn't the usual behavior of AVG program. Let us work towards fixing the issue.
Check if there is already a corrupt application has been installed.
And also share us the screenshot of that message?
Refer this article for the steps to capture the screenshot : https://bit.ly/2Y6RCDP
I recently paid my subscription for Password Protection. I click on install. It seems to go through the process but then I'm told in BIG red letters that "Your subscription has been cancelled". What's going on? I've not experienced this issue before. Is there a simple fix? Note my emphasis on simple as I'm not very computer savvy. Cheers
Hi Jonathan,
