Hello Randy,
We can help you in fixing this.
Perform repair of AVG PC TuneUp and check the status with browser cleanup.
If the issue persists, we can provide additional support in fixing this.
Have you purchased the license for AVG Driver Updater product or is it "Driver Update"?
09/22/2018
AVG,
My ID # is 865 668 92.
1) I just recently had problems my 2 laptops. The original problem occurred when I tried to run the AVG tune-up program. What happened was the tune-up program would get stuck when it came time to clear the browser. I would get the message that said "try again". I would click on the try again button and it would come back on. The tune up program would not go any further than that until I clicked on "skip cleaning". Then I would get the message of "browser skipped". The results would show all green for the tune-up.
2) Since having the work done on my the MSI laptop, I sometimes get a message stating basically that my computer might not be protected. The ESET antivirus program was taken off. I was told that the ESET anti-virus program that I had was in conflict with the tune-up program.
3) The original problem of the tune-up program is still not working properly. Even though my laptops were worked on by your people. Even though it seemed as though they had fixed the problem. I have been really satisfied with your tune-up service up to now but the problems don't seem to be completely fixed. I am still having problems. If it turns out that my computers are so old that I need to have new computers, then I need to have my "driver update subscription" cancelled and my subscription money returned to my account.
4) My 2 "fix it" sessions numbers are 071 381 37 and 106 971 411.
Hopefully I will hear from you soon.
Thank you for your time,
Randy Brumund
Hello Randy,
