Problems with update
Hi Steve,
For help on your issue please try remove AVG TuneUp using this tool and than install latest version form our web back.
Hi Steve,
Just tried running UpdateWizard.exe by double clicking on it: same error message.
When I try to update, after downloading I get the following message: "The program 'UpdateWizard.exe' is not responding. Please close the program and click OK to continue."
According to Windows Task Manager, nothing called 'UpdateWizard.exe' is running. I closed SilentUpdater from AVG, which stops the entire process.
