Hello, I have a number of AVG products but as it happens when my computer is just finishing loading the desktop, I believe it is Internet Security 2015.
Hope you can help.
Robert
Hello Robert. Sorry to hear that. Thank you for providing the information. Avgntopensslx.dll is a type of DLL file associated with AVG Internet Security developed by AVG Technologies CZ, s.r.o. for the Windows Operating System. A Uninstallation and reinstallation of the AVG Internet Security program would fix this issue. Please follow the below mentioned instructions:
1) First step is to use AVG Remover tool and uninstall your AVG program completely. To download AVG Remover Tool please click on the following link:For 32-bit: http://download.avg.com/filedir/util/support/avg_remover_stf_x86_2015_5501.exe
For 64-bit: http://download.avg.com/filedir/util/support/avg_remover_stf_x64_2015_5501.exe
when staring up error message "procedure entry point AvgLibCryptocleanup could not be located in the dynamic link library avgntopennsslx.dll". I am not able to open avg 2015
Hope you can help.
Robert
To download, install and activate AVG Internet Security program please follow the instructions mentioned in the following article: http://bit.ly/1DXPL5z .
Please feel free to contact us should you need any further assistance.
