Hello Jim, I am sorry for the inconvenience caused to you. I do understand your concern. I request you uninstall Adobe Reader and re-install it. I hope this will fix your issue. Thank you.
I recently installed AVG 2015, and since that time my HP plotter will not print .pdf files. I get a message about Live Optimization and something about problems with Adobe Reader.
Also, my Earth Survey plugins do not work in Google Earth. All of this worked before the install.
Should I do a system restore, and if so, will my AVG still be there?
