Protection on my second device not possible?
Hello Phillip,
We regret for the inconvenience caused. Please check whether you have installed any other conflicting applications like McAfee, Avast, Norton etc… on your PC, If so please uninstall the conflicting applications.
If not, please  click this link http://aa-download.avg.com/filedir/util/AVG_Remover.exe to download and run the AVG Remover tool to remove all the traces of the AVG.
3. After the restart,  manually delete the AVG Remover folder in the C drive of My computer.
4. Once uninstalled download the installation file using the link : http://www.avg.com/download to reinstall your AVG program.
Phillip, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Unable to upload AVG Protection on my Second Device, uploaded fine on my Laptop.
