Quick Tune: Analysis Required
It means click "Fix Performance" so AVG can try to sell you PC TuneUp 2015. For example, if you never delete old Windows error reports, the analysis will show you have a serious problem with "junk files."
You can go to control panel>add or remove programs>select AVG>click modify and uncheck Tune up component>click next to finish the process. Restart your PC when done. Thank you,
I get a banner that comes up in the lower right hand corner that say "Quick Tune: Analysis Required", what does this mean?
