Thank you for the quick reply!,
I did everything you said but unfortunately still same notification
installation Failed
Error Code: 0xC0070643
Description Event exec_finished
Do you have any other ideas?
Thanks in advance!
My AVG Internet Security didnt work properly.(kept saying something was wrong and that I wasnt fully secured) I removed the program to re-install. Unfortunately, after three times trying not yet succeeded. ( I tried to install a trial version just to be safe till I fix this but this to woudnt install)
Please help me im using the internet now without protection ![]()
notification:
installation Failed
installation Failed
Thanks in advance!
I solved the problem! dont know how just kept trying different things.
Thank you so much for youre support!
Yes I did, I have 64bits. To be honest I tried them both just to be sure.
I even search my computer manual to see if I can find anything left. But nothing.
Do you have any idea were these old files may be?
