Thank you for clarifying us with screenshots, Ran.
Is this website 'intripment.com' a legit one? Do you receive this pop-up when you manually visit this website or it it occur randomly when you open the browser itself?
Please make sure that you're using the latest version of AVG AntiVirus installed on your Mac.
Keep us posted here.
Hello Ran,
Could you share the screenshot of the threat detection window by clicking on "see details" from it?
May I ask whether you get the threat detection popup whenever Mac is started or only when you access sites through Safari browser?
If it is happening while accessing sites through Safari browser then please check whether it happens with other browsers installed on your Mac.
Hello,
I've been having this issue with a threat that keeps popping up.
Every time, AVG says the threat has been secured, but it keeps reappearing.
The website is called 'intripment.com' and when I try to have a look at it, I'm being blocked, saying it's a malicious website.
any help on how can I permanently remove this threat?
I'm using MacBook Pro running Mac OS Mojave.
Thank you for the information, Ran.
I request you to reset your browsers and check the status.
Thank you for trying, Ran.
I have sent an email for additional support to resolve it. Please check the email and follow the instructions.
This could be caused due to adware application or malicious browser extensions.
1.) Please review all your installed applications and you can uninstall unwanted applications from your computer.
2.) Refer the article to reset your chrome: https://support.google.com/chrome/answer/3296214?hl=en
Follow the below steps to reset your Safari browser:
Select 'Privacy' at the top of the new window that appears, and then click the 'Manage Website Data' button. In the next dialog box, click 'Remove All'. It will ask you if you are sure you want to remove all data stored by websites on your computer.
When you say reset you mean closing and re-opening? If so, I've done that several times already, as well as restarted the OS.
And when you say 'check the status', do you mean just having a look if it re-appears? If so, the answer is yes. If there's another action I need to do, please do let me know.
I've done all these, including going into all tabs in safari and deleting every website that was registered or permitted to do anything.
It worked for a few minutes and then recurred again
