Reinstall but problem connecting to AVG servers
Hi
I had Update problem
So, I had to reset one of computers that I set registered under my AVG and was wiped clean. So I tried to reinstall AVG and a problem occurred. I clicked to install, but it would pop up and look as if it was going to load and start download, but something would pop up. It would say, "We are sorry but there seems to be a problem connecting to AVG servers! Check your Internet connection and run the installer again." So I tried restarting my computer, the same issued happened. Then I restarted my router, it happened again. I looked at the subscription and the subscription status said unavailable. Is there any way to fix this so I can put AVG on the computer that I had to reset?set?
Hi Mohammad,
Please let us know the operating system of your computer in which you're experiencing this issue & the name of exact AVG program that you're attempting to reinstall. Reason being, we're unable to find any active subscription under your account. It might be registered under your alternate account.
Note : It isn't recommended to share the account info over this public post.
