Restart required
Hi John,
Please let us know the version of AVG installed on your computer. (Open AVG - Menu - About).
Have reinstalled AVG. Restart message appeared on first execution. Did a restart
then rexecuted AVG & Restart message no longer appeared.
Thank you  Santhosh & Dinesh – John Gallant
AVG runs fine. Last Update indicated "Restart Required" when update finished.
Did a restart. Now whenever I run AVG I still get the 'Restart Required' message
Doing further restarts does not fix the problem
Hi John,
Thank you for the information, John.
We request you to uninstall the AVG Internet Security from the control panel and reinstall the program.
Refer this article for installing the program https://support.avg.com/SupportArticleView?urlname=Install-AVG-Internet-Security
Then check for the issue again.
Keep us posted.
AVG version is : 19.8.3108 (build 19.8.4793.541)
Virus definition version is: 190930-4
UI version is : 1.0.189
John Gallant
Thank you Dinesh
UI version is : 1.0.189      John Gallant
