Same problem, running Windows 10 Home and AVG Free. Functionality broke just over a week ago. It would appear that this is not version-specific. I used CCleaner to disable the AVG Shell Extensions (avgsea.dll file) and everything is fine now.
Hello Faique,
We regret the inconvenience caused. I have just sent you an email with the instructions to get connected with our senior technical support team. Please follow the email instructions to get additional support regarding this issue. Thank you.
Windows 10 Pro x64But with all latest windows updates
AVG Protection Pro with AVG Zend.
From past 3 days (same issue on 3 systems with windows 10) whenever i right-click on any folder or file my system gets stuck and then explorer.exe crashes. Microsoft Support guided me to download a software named "ShellExView" which allows to disable all the softwares which integrate with explorer.exe on right click.
As i disabled AVG SHELL EXTENSION CLASS version: 16.71.0.7597
my problem got recolved. But it only stays disabled until restart. So everytime i had to disable avg from it to stop my explore.exe crashes
Kindly release a update to solve this bug or guide me to downgrade AVG to past version since it was working perfect before 3 days on every system and is reacting like this after whatever update it installed itself.
