Ring Chime for Ring Doorbell
Hi Beverly,
From your description, it seems that AVG Secure VPN app is set to turn on automatically when connected to public networks.
In this regard, you can either try to manage the network profile (from public to private) in your Secure VPN app or disable the auto connect feature, by following the steps in this article.
Additionally, please ensure that local device access is enabled (Open AVG Secure VPN - Menu - Settings - General - check 'Enable local device access' box.
Please try the above steps & let us know if it helps.
Hi Beverly,
I am trying to set-up the ring chime for my ring doorbell. However, will not let me disconnect from VPN to complete the set-up. Shows that VPN disconnects but reconnects before I can complete the set-up. HELP.
