Hi Dale,
For help on this issue please try reinstall AVG according to this article.
Hi Dale,
While running a Full Scanin w/AVG Int Sec 2015, the AVG program locks up at the same place
and won't continue.Click on Stop and it still shows it running. Finally get to a Shut Down where it takes awhile to actually do it.
Here's the Scan In Progress screen wher it locks up:
28%
11414 (this number seems not to be constant)
Registry
C:\Windows\SysWOW64\Shell32.dll
No threats indicated.
Ran 1-click maintenance - perfoemed fixes and nothing changed.
Ran AntiMalWare Bytes - it found nothing.
Uninstalled Google Chrome, which I wasn't using anyway - no effect. I use IE 11.
Everything with the PC operations seems to work just fine. Help!
