Thank you for writing back to us, Jake.
We understand that the "Sage 50" is an accounting application.
We'd like to inform you that this is the expected behavior as most of the banking, accounting and streaming websites will have their own restriction policy which will not allow access when a VPN application is used.
However, you can try selecting the following locations Gotham, Miami, New York, Seattle, Wonderland in AVG Secure VPN and check whether you are able to access the accounting or banking sites.
Thank you for understanding.
Hi Jake,
We are sorry to hear this.
Are you able to open the program when the VPN is turned off?
Please try to change the location and check for the issue again.
Keep us posted.
Thank you for the clarification, Jake.
Please try changing the location of your AVG Secure VPN to different locations (such as Gotham, Miami, New York, Seattle, Wonderland) and check if the issue persists.
Keep us updated.
Hello,
I am having what appears to be a fairly regular problem where Sage 50 will not launch while AVG VPN is running. I can log in fine, but the actual program itself never opens. No crash report either. I've already tried to add the folder that the program is in to the list of exceptions, but that wouldn't work. Any solutions?
Hi Jake,
Keep us posted.
