Scan problems with AVG Anti-Virus for Mac
I am having a similar problem… on a brand new mac book pro… avg was the first thing i did and it is conected to the zen network as well…
Hello Marcus,
I understand the inconvenience caused, let's work together to fix this issue. This might be because of update issue. In this case, I request you to reinstall AVG Antivirus on your Mac computer. You can follow the instruction (http://support.avg.com/SupportArticleView?urlname=How-to-uninstall-AVG-AntiVirus-for-Mac) to Uninstall AVG program and also you can follow the instruction (http://support.avg.com/SupportArticleView?urlname=How-to-download-and-install-AVG-AntiVirus-for-Mac) to download/install AVG Antivirus. If the issue still persist then please let us know your Mac operating system version to assist you further.
Best regards,
My AVG Anti Virus for Mac scans reach 99% then takes forever to finish.
This is without external hard drives plugged in and seems to cover mobile back ups by the time it exceeds 99% of the process.
Is there an obvious problem causing this and a solution?
Thanks for any guidance,
Marcus
Hello Marcus,
Best regards,
Thomas,
I regret for the inconvenience caused. Have you tried to uninstall and reinstall your AVG Antivirus as per the steps mentioned in previous post? If you haven't tried that, I request you to follow those steps and check if it works.
