Hello Smith,
Thank you for reaching AVG support channel. We understand that you wish to remove scan recycle bin suggestion from context menu. We will check and help you to resolve it.
Please provide the following information to help you better :
1. Confirm the version of operating system installed in your device.
2. Share us the screenshot of the notification (or) option which you want to remove.
3. What are all the AVG programs installed in your device?
Hello Smith,
My AVG is show double 'Scan Recycle Bin using AVG' on context menu on the 'Recycle Bin'. How can I remove both? I don't want this feature.
I searched and found nothing…
This is a usless info. I have others PC installed with AVG with this removed. Why in hell you want to AVG on the recycle bin. APPLE.
Thank you for taking out your valuable time to sharing the information.
We would like to inform you that, this default option to scan each application.
Since you have AVG Internet security application, it will protect each application and give option to scan each application.
We appreciate your understanding and cooperation.
Running on Windows 11 Pro 23H2.
Installed version: AVG Intenet Security on Windows 11 Pro 23H2.
Hello Smith,
Thank you for writing back to us. We apologize for the inconvenience caused. We can really understand your concern. We are sorry to inform you that AVG program does not have option to disable the "Scan Recycle bin using AVG". Kindly check Windows device settings to disable this option. Hope you understand our limitations.
