Scheduled Scans not starting
Hi Adrian,
I have checked the details It seems that you have the AVG Antivirus Business edition part, You are connected to AVG Technical support for home products.
Please kindly provide the details for AVG Home products you have.
Hi Adrian,
We regret for the inconvenience, Unfortunately the issue which you are currently experiencing is a known issue and it has been fixed from our side recently.No need to worry.
In this case we recommend you to re-install your product and check whether you are able to resolve your issue at the earliest.
To uninstall the AVG Program please follow the below process.
start->control panel->Programs(uninstall a program)->AVG(Uninstall)
After Un-installation please click on the below link for re-install AVG free.
http://files-download.avg.com/inst/mp/Antivirus_Free_1817.exe
OS:Windows 10
Just updated to AVG Free 2017, my original scan config was no where to be seen, had to create a new one. For a test set scan for 15 minutes after I had finished configuring new scan parameters…scan did not start…perhaps if I wait…no start…changed scheduled time to later (roughly 20 minutes)…still no scan start up…what!?? Need a resolution…
Adrian, Also there isn't an AVG Free 2017 Business Edition prog…
I haven't used the AVG Business Edition in years literally. I am no longer in business! This is a home computer with previous installation of the AVG Anti-Virus Free Edition 16.151.8012 which was just this morning updated to the AVG Anti-Virus Free Edition 17.3.3011. I am neither a rube, inexperienced, or stupid, I know what I am talking about, I'm not drooling in my shoe…you are being presumptuous…You need to listen to your customers, I know this because I am a former Network/Hardware Consultant and Designer/Installer, and had to listen to customers and not prejudge them. I need a simple resolution to this issue…I have used AVG paid and Free over the years with great satisfaction and have recommended the same to others… it's never grossly failed in the past until this moment…I have, at this moment, NO Business edition or any other paid home product, just the AVG Free…now can I please get at least an attempt at trouble shooting this issue???
Hi Adrian,
