Screens too small
Hello Pasul,
Thank you for reaching AVG Support channel. We are sorry for the inconvenience caused. We understand that you are having issue with AVG Tuneup as its user interface appear too small. We will check and help you.
Please provide the following information to help you.
1. Confirm the version of operating system installed in your device.
2. Let us know the device make and model where you installed AVG Tuneup.
3. Have you tried to reinstall AVG Tuneup and check it?
4. If possible, please confirm your device display size?
5. Share us the screenshot of the page where AVG Tuneup appears too small.
You can post the screenshot here in your topic. Click on Answer & then click on the Image [mountain symbol] & follow the instructions. Thanks in advance.
Hello Pasul,
Using AVG tune up.  The screen is not full size and there is no expand screen option.  There is no scrool do0wn section either so I cannot see what is further down.  Any suggestions
