Hello Marie,
Please open AVG Secure VPN program window.
Click on "gear" icon to open settings.
Click on "Network Security" and check whether the box that says "Exclude Trusted private network" is selected.
If yes, uncheck it and then restart your PC. Your AVG Secure VPN has to be turned on.
I continue to get errors when trying to load websites. "Your connection was interrupted A network change was detected. ERR_NETWORK_CHANGED Reload" This happens at random times with multiple websites. I changed my location, flushed the dns settings, updated my IPv4 and IPv6 settings as well as multiple other options that I have found on the internet for help. The only thing than seems to make a difference is if I don't use the VPN at all. I am connected via ethernet connection but live in an apartment complex and need additional security for my job. Again, this happens at random times on all websites.
Thank you
We appreciate your effort, Marie.
Could you disable AVG Internet Security "Enhanced firewall" feature or any other 3rd party firewall temporarily and check if you can access those websites?
If the issue persists, We'd request to uninstall AVG Secure VPN and reinstall it to check if that resolves the issue.
Keep us posted.
It was already unchecked, no changes were made
Thank you for the confirmation, Marie.
In this regard, we'd suggest you take advantage of our free additional support.
To connect with them, follow the steps that have been sent to you via email.
I already uninstalled and reinstalled it. I am using AVG for antivirus.
