Secure VPN "ran into a technical problem"
Hello John.
We are sorry for the inconvenience.
I'd like to offer you a free remote assistance service to troubleshoot and resolve this issue.
I have sent an email containing steps to get connected with them.
Check your inbox and spam box as well.
the VPN fails to load.  After a search here I rebooted and tried again, uninstalled, rebooted, re-installed but the position is unchanged.
I then tried to fill in the customer help form, which is broken as a) the yes/no button can't be changed and b) is will not subit the issue.  Eventually I managed it using Edge, once, only to be told that Chat isnt available and then got back into the broken form loop again.  Lost faith in AVG which has seemed ok if expensive.
Ideas anyone?
Hello John.
