- Run the downloaded tool and follow the instructions displayed on your screen.
4) Your computer will be restarted automatically. After the restart, AVG Remover will finish the uninstallation.
To download, install and activate AVG Internet Security program please follow the instructions mentioned in this link: http://bit.ly/1DXPL5z .
To download, install and activate AVG PC TuneUp program please follow the instructions mentioned in this link:
http://bit.ly/1ERJxSd .
Hello Chris. Sorry to hear that. I would request you to follow the below mentioned instructions:
1) First step is to use AVG Remover tool and uninstall your AVG Internet Security program completely. To download AVG Remover Tool please click on the following link: http://download.avg.com/filedir/util/support/avg_remover_stf_x64_2015_5501.exe
2) To download AVG remover tool to remove AVG PC TuneUp program please click on this link: http://www.avg.com/filedir/util/TuneUp_Remover.exe .
I purchased Internet Security 2015; 1 computer, 1 year, exp. 03-13-2016. Every time I try to run it, it stops with "Following AVG processes failed: -oneclick.exe" I've clicked YES on the "Send Report" several times, but I never get any reply from you. I paid $55.18 USD for this.
Also, the same thing happens when I try to run AVG 1-click Maintenance, with the same message, and I click YES on that "Send Report".
I like your products. I also paid good money. Don't you think this should have been fixed by now?
Thanks. Chris.
