Serviio problem
Hellow Bhuvaneswari,
Thank you for help, but it just not worked for me. I followed all the instructions, but unavailingly :frowning:
It must be something else.
Best regards.
Eduard.
Hi.
My name is Eduard.
I have a problem with one of my programs after last AVG update (17.4.3014). The problem is with Serviio Media Streaming Server. After last update, AVG Firewall blocks this program, and I can't use it. When I turn off firewall, the program (serviio) is works normally (I see it on my TV). I tried to change the settings of firewall, but unsuccessfully.
Can you help me, please?!
Best regards.
Eduard.
Eduard,
Thank you for trying our suggestions and I appreciate your efforts and patience. To assist you better, I request you to get connected with one of our expert remote technicians. I have sent an email with steps to establish a remote connection with them. Please check your inbox and spam/junk folder as well for the email.
Best regards.
Eduard.
Hello Eduard,
We are sorry for the inconvenience caused. We will certainly help you with this. Please follow the instructions to change the Firewall settings to fix the issue : Open AVG Internet Security -> Click on Menu in the top right corner -> Settings -> Components -> Firewall -> Customize -> Network Profiles -> Change the networks from Public to Private (If it is in Private, change it to Public).
Also, on the same Firewall settings, please drag down and click on "System Rules" and Enable all the configurations.
Please do contact us if you face any difficulties, we will assist you better.
Hello Eduard,
