Setting up HP PHOTO CREATION PROBLEM
Hello Spiros,
Thank you for reaching AVG Support Community.
We will certainly check and help you to resolve it.
May I know the AVG application which installed on your PC? i.e, AVG AntiVirus FREE or AVG Internet Security.
Do you get any pop-up notifications from AVG? If yes, please share the screenshot of the AVG popup.
Please refer this article & diable the AVG AntiVirus FREE/AVG Internet Security on your PC and check whether you're able to install and access the application.
If you're able to access it, when the AVG is turned off, then update us through this community post.
Hello Spiros,
Hi to everybody!!
I reinstalled windows last days to face a serious software problem in my HP Laptop and after setting up the printer I tried to setup the HP PHOTO CREATIONS application. All may attempts failed because the free AVG protection blocked the URL. It's imposimple to proceed the setup procedure thank to AVG not offered a capability to disable for limited time. Can some body help me?  Thank you in advance…
