Hi Carl,
We apologize for inconvenience caused. We would like to inform that the case has been moved to our developers. We request you to wait for some time, so that our developers can fix the issue. We will notify you once the issue is fixed.
Thank you!
On 4/30/17 I posted that I was having trouble setting up and running Scheduled scans since my AVG (free) updated to Ver 17.3.3011. I received a response to run the "Repair" on the AVG software. I did that and it completed successfully. However, the AVG screen still shows that the last time my PC was scanned was … the last time I did a manual scan. I decided to check the report and found that it showed the results for the Scheduled scans. Because of this I have no way of knowing that my scheduled scan was run unless I open the report page. I'm assuming that AVG is waking up my PC at 2 AM to run my scheduled scan … that's the time shown on the report log. (that is also the time I set it to run) The old version could not wake up a sleeping PC. Can someone give me some direction to better utilize Scheduled scans? Thank you.
Hi Carl,
Thank you!
Other user Carl Phelps posting (https://support.avg.com/answers?id=906b0000000Dl5BAAS).
