Settings wont opoen
Hello Gerry,
We understand that after AVG update your are facing issue with settings app of Windows 10.
We are really sorry to know this. We'll certainly check and help you out.
Could you please let us know which AVG applications you have installed on your device currently?
Could you please let us know if you get any error message while you open the settings?
Have you updated your windows to latest version?
It may also help us to diagnose the issue you are experiencing if you can attach a screenshot of the problem. If you are not sure how to make a screenshot on your device, please find instructions for a variety of devices here: | AVG (https://support.avg.com/SupportArticleView?l=en&urlname=avg-create-screenshot)
Awaiting for your response.
After the recent AVG update, my settings app in windows 10 will not open.  It tries to start but crashes
Thank you for writing us back and sharing the information.
We suggest you to try disabling AVG Antivirus and check if you still face issue with the windows settings.
Right-click the AVG icon in the System Tray. This is located in the lower-right corner of the desktop. …
Click Temporarily disable AVG protection.
Choose how long you want the protection to be disabled and whether to disable the firewall as well.
Click OK.
Please do check and let us know.
Hello Gerry,
I have the latest edition og AVG FREE installed on my pc.  24.7.9311.855  There are no error messages when the Settings app fails to open.  Within 4 sec of the main settings screen coming up. the app simply closes.  I'm running Windows 10 and had the latest updates installed before this issue with the latest AVG update required a restart of the pc.  No screenj shot to share
