ok I can't believe throttling downloads by >70% is "slightly" slower. Not inclined to purchase. I'll look elsewhere.
Hello,
I have a 7 day VPN trial and I am noticing a great slowdown in download speed with the VPN. I understand some slowness, but Really? 173 mbps w/o vpn. 60 mbps with vpn. The test done several times with similar results. I am not sure I want to continue with purchase.
We understand your concern.
This is an expected behavior. You may sometimes experience a slower internet connection when using AVG Secure VPN. This is because VPN encrypts traffic and data before sending it to a server. Depending on the distance and capacity of the server, this process may cause a slightly slower, but safer, internet connection.
Thank you for understanding.
I regret for the inconvenience.
I suggest you to try connecting to different optimal location and P2P servers in AVG Secure VPN and check if experience any difference.
