So AVG destroyed my pc and refuses to help fix it
David, Before you attempted to downloaded AVG did you totally remove Norton (https://support.norton.com/sp/en/uk/home/current/solutions/kb20080710133834EN_EndUserProfile_en_us)?.
So I downloaded AVG anti virus free trial because I had read that it was better than Norton (My previous antivirus software) and wanted to test it to see if it was worth the purchase. When I downloaded AVG it told me it had to reatart and scan my files so I could be protected. Once it had fully restarted my pc I noticed that my background had been changed from a picture of a car to purple. Also not a single one of my programs was working, nor was my search bar or most of the things in control panel. I tried to reset my pc to a previous save point and all of my save points were deleted. I went and ran a program which searched throught my system files and it said most of my system files are corrupted. I called AVG and they said to uninstall AVG and it would fix my problem. After uninstalling AVG and having nothing fixed the AVG suppor said that because I no longer had AVG on my pc they can't help me and are telling me to contact a local technician. I think it's awful that this company won't help or own up to their mistakes. Can anyone please help me?
