Speed reduction with VPN
Hello Tracy,
Depending on the distance and capacity of the server, this process may cause a slightly slower, but safer, internet connection.
You can check with the internet speed by installing AVG Secure VPN as suggested here: http://support.avg.com/SupportArticleView?urlname=Install-AVG-Secure-VPN
My typical download speed is +150-200 Mbps, per Ookla. What amount of speed reduction would I expect from adding the VPN.
Hello Tracy,
