Same old, Same old cut-and-paste non-answer.
"You may sometimes experience a slower internet connection when using AVG Secure VPN. This is because VPN encrypts traffic and data before sending it to a server.
Depending on the distance and capacity of the server, this process may cause a slightly slower, but safer, internet connection."
Load of testicles.
Hello Pablo,
We are glad to clarify this to you.
You may experience a slower internet connection when using AVG Secure VPN. This is because a VPN encrypts traffic and data before sending it to a server. Depending on the distance and capacity of the server, this process may cause a slightly slower, but safer, internet connection.
With VPN on the network speed is reduced to 500mb to 100mb. Something to do to solve this problem.
Load of testicles.
Hello Pablo,
