Start up problem
Hello Johan,
Sorry to know that you are facing startup issue with your PC running Windows XP pc.
From when you are facing this issue, Is it before installing the AVG Performance or after installing it?
Answer to your second question is Yes, If you purchase our latest AVG Performance program for Multidevice then you can install it on unlimited PC's running Windows Xp SP3 and above and Mac and Android Smartphones and Tablets.
Did you create the System Restore point for your OS?
Is your version of Windows Xp is Service Pack 3?
Thanks for your brilliant product.
My problem is with start up.  I have Windows XP.  When I start up my PC, my monitor stays black just before the curser accur and before the welcome screen.   Then he stays black.  I installed AVG Performance but the problem stays the same.  I know I have 1 day trail but I can't by if it cannot fix the problem.
Can I run 2 cumputers and 2 tablets on the same packedge.
Johan
Hello Johan,
