Hello Juri,
We regret for the inconvenience caused. We believe that you have tried the 'trial' version of AVG and so once the 'trial' period is over you may get pop-ups to make sure that your PC/laptop's advanced protection is continued. To uninstall 'trial' and continue using 'free' version, follow these steps. Please remove conflicting antivirus products if any (http://avgread.me/1K1IqEh) and then remove AVG traces using remover tool( http://aa-download.avg.com/filedir/util/AVG_Remover.exe ). Please restart to complete the uninstalling process. After restarting your computer, you may need to manually delete any remaining AVG files and also 'search' for a folder "AVG Remover"(usually in 'C' drive) and please delete it manually. And then install your 'AVG Antivirus Free' by clicking on http://files-download.avg.com/inst/mp/AVG_Antivirus_Free_692.exe .
I don't want to limit the pop-ups, I want them REMOVED! And I don't want to upgrade to Pro just to remove these pop-ups. I've been using AVG almost from when it was first released and I've always used the FREE version. However, because of constant nagging by your company I tried the Pro version and decided that I didn't need or want it. That's when these pop-ups started, telling me that my trial period had expired and exhorting me to upgrade! THAT WILL NOT HAPPEN!!! If I can't resolve this blatant blackmail to my satisfaction I will use my Revo Uninstaller Pro (paid version) to remove every trace of AVG from my system. And if this doesn't work I will simply reformat my SSD and reinstall my Win7 64 bit OS. So get your act together or you will have another very irate ex-customer.
Juri, And then have a look at http://support.avg.com/SupportArticleView?urlname=How-to-Change-the-Frequency-of-Pop-Up-Notifications .Thank you.
