This appears to be a virus. Certain keys such are r, i, numbers 0, 4 cause the Windows shell32.dll to try and run prograammes. Initially it was Windows Media, which I shutdown, then it was another Media video program–which i uninstalled—then it kept coming and asking to say which programm should run with a certain dll extension–i tried to direct it to Adobe pdf—and now it is stuck on that and opens Adobe pdf reader constantly–I have to shut it down and cancel etc etc --this has been happening all day–now my wife has somethinmg similar on her computer---- It happens on windows and other programmes-----very weird
This appears to be related to a windows file/programme, shell32.dll --it opens up media programmes and now unfortunately i directed it to Adobe as the file extension to open and it opens Adobe all the time–driving me crazy—
Hello Geoff,
Please specify your concern with AVG which will help us to understand and assist further.
No it is nothing to do with Adobe. If you read careful my description of the problem above you understand why. See my 2nd comment above. try again.
The error looks like that one of the file of Adobe is missing.
I request you to reinstall Adobe application to check whether it resolves the issue.
If the issue persists, please contact concern support to get further assistance.
Geoff, if you consider it as a Windows issue, then contact Microsoft support to get further assistance.
If the issue is due to AVG, we will be able to assist you here.
