Strange Blue Circle for notifications will not go away
WARNING: TECH SUPPORT - DO NOT, REPEAT, DO NOT TELL ME TO REPAIR THE INSTALLATION, TO CLEAR THE INTERNET CACHE, TO REBOOT, TO REINSTALL THE PROGRAM, DO NOT SUGGEST THAT I DO ANYTHING, AT ALL, NOTHING, TO MY COMPUTER. WARNING: TECH SUPPORT - DO NOT, REPEAT, DO NOT TELL ME TO REPAIR THE INSTALLATION, TO CLEAR THE INTERNET CACHE, TO REBOOT, TO REINSTALL THE PROGRAM, DO NOT SUGGEST THAT I DO ANYTHING, AT ALL, NOTHING, TO MY COMPUTER.
Perhaps other customers on the forum, or tech support people who are using AVG Antivirus Free, can comment on this problem. I say that it is a bug, a failed feature, it is supposed to be this way, it is messed up. In the last few weeks, when the AVG Antivirus Free wants to let you know there is a "notification" it no longer just displays a little popup at the system tray, now it displays the popup PERMANENTLY ALONG WITH A STRANGE BLUE CIRCLE OVER THE SYSTEM TRAY ICON, FOREVER, UNTIL YOU CLEAR THE NOTIFICATION!!! What in the world, what kind of a system is that? I used to review the notifications and clear ten or more at a time, now it forces you to clear every single message!!!
This isn't the experience we want you to have. We'd like to help you with this.
Upon checking the provided screenshot, we see that AVG notification settings need to be modified.
To do so: Open AVG Antivirus - Menu - Settings - General - Notifications - Enable 'Use silent mode & the option beneath it'.
Please try the above step & let us know if it helps.
