System crashing after Tuneup utilities 2014 adjustments
Pavol Sokyra quote 'Where can I upload files related to this issue?'…
Pavol, You can use the AVG FTP server (https://support.avg.com/SupportArticleView?q=ftp%20server&urlname=How-to-upload-a-file-to-our-FTP-server).
Hello,
after 1-click maintanence and registry defragmentation i went to TU deactivation (function that enable/disable programs) and after I disabled Virtual clone driver my windows crash to blue screen and restart. After windows restart I had 800x600 resolution which was not the case before crash. Then several same crashes appeared while different kind of actions with my PC. I have not had theese issues before I installed TUU 2014 so I think it is realted to this.
This is screen with windows message after the fourth crash:
https://imagizer.imageshack.us/v2/803x643q90/540/Ntx7kz.png
Where can I upload files related to this issue ?
Thank you for your time.
Regards
