Hello Jerry. Yes System Restore won't work if the antivirus program is active. Were you able to disable the AVG Antivirus?
System Restore does not work with AVG on.
Yes I could. Some time ago I asked this question to AVG and they said I should not have to deactivate AVG to use System Restore and said they would need to check my computer to fix the problem. I use Vista Home Premium and Windows PC.
My brother uses Windows 7 and has the same problem.
