Hello David,
AVG Protection will never delete restore points on your computer.
Do you have AVG PC TuneUp installed on your computer?
Did you optimize your computer using AVG PC TuneUp?
Since installing my trial version and everything was working, I decided to set a restore point. Not only was I unable to do this, previous restore points were not shown. Does AVG delete restore points and prevent others from being set? I have used restore points in the past to fix some annoying problems - usually found after a Windows update. How do I get the restore point system function working again?
Hello David,
