Sorry to know that your issue persists after resetting the browser.
We request you to try reinstalling the Google Chrome browser completely and then check whether the issue persists.
Hi Balasubramanian,
I've already reset that too, and it still persists. Also, I'm using the free version, if that helps.
Ka
Hello Ka,
These are caused due to some malware or adware programs installed on your PC and these usually take over the browsers and cause annoying popups and redirecting webpages.
AVG programs are capable of detecting and removing the malware and adware programs, however there are numerous number of malware programs emerging day by day and we are working 24/7 to add all those definitions to our database.
We can understand that you have already tried disabling the add-on and scanned using AVG program but have you tried resetting your Google Chrome browser once? If you reset your browser your saved bookmarks and passwords will get deleted. If it is okay for you to reset the browser, please go ahead for it and let us know the status.
Please mention whether you are using the free, trial or paid version?
It's been about two days since I noticed my Google Chrome has been redirecting to tech-connect.biz website instead of my set google homepage on start up. I already ran AVG security twice, as well as PC analysis, deleted and re-added my google profiles ( with different emails ), deleted and disabled extensions as well as tried to find the malware myself on the pc. I fear there's still some leftovers that the antivirus run has bypassed. Help before it gets worse?
Hello Ka,
Hi Balasubramanian,
Ka
