Technical problem, no connection
Hello Haluk,
We understand that you are having a connection issue after a recent update with windows.
We are really sorry to know this. We'll certainly check and help you out.
Could you please let us know if VPN is on ? if so please disable and check.
Also we suggest you to try disabling AVG Internet Security and check.
Here is an article for disabling AVG: | AVG (https://support.avg.com/SupportArticleView?l=en&urlName=disable-avg-antivirus&q=avg+disable&supportType=home)
Awaiting for your response.
Hi, after last windows update (kb5032189) I have a connection problem.But there is no error code/number. How to fix?
Hello Haluk,
