I get the message:
"They are not fully protected!" Web: The LinkScanner component is not active. "
I set a sign into the checkbox for activating the link scanner, but I get this message every time.
Version: 16.111.7797
What can I do? - Thanks for answers.
Best regards, Peter
Peter,
We are sorry to hear about the inconvenience caused. We appreciate all your efforts, we would suggest you to reinstall your AVG program in order to fix this issue. Click this link http://aa-download.avg.com/filedir/util/AVG_Remover.exe to download and run your AVG removal tool which uninstall all your traces of AVG completely, once the tool is run, your PC will automatically reboot. After the restart, please check if a folder with name AVG Remover is created under C: and remove it. Then, go to this link http://www.avg.com/us-en/download and download your AVG program. Let us know if you face any difficulties, thank you.
