Threat Secured Pop Up Not Going Away
Damien, http://update2.mybrowserbar.com/ might be an unwanted search engine in your web browser. Please make sure your web browser is clean of unwanted search engines, add ons or extensions. Also make sure your AVG is up to date with latest virus definitions.
Hi Damien,
We will help you to get this issue resolved.
Please share us the screenshot of the threat secured pop up from AVG to check and assist you further.
This pop up continues to come up. It stays on my screen and I can't remove it…
when I click on the X in the top right hand corner it removes the pop up TEMPORARILY. It reappears almost immediately.
Please help as i can't use the screen with it there…
There is nothing in Quarantine to delete.
I am running Windows 10 and Chrome. Thanks for your help
Tried to load image but there is no URL associated with the pop up
Hi Damien,
It is random.
I don't understand by what you mean "reset your web browser".
Pleaese be more specific about what steps I need to take... thanks
