Hi David,
We're glad to help you.
Initially, we'd suggest you to disable each shield individually to identify the component causing the issue. To do so, open AVG program on your MAC & click on Computer tile to click on the toggle bar beside a shield.
Once we identify the component, we'll be able to proceed accordingly.
Also, the steps to manage settings in AVG program can be found in this article.
Regarding the issue on iOS, we'd suggest you to raise a ticket to our mobile team by visiting this link.
Both with iOS and macOS I am finding that Ticketmaster website app and website will not work completely with AVG present. On iOS it states that Javascript may not be on (but it was) or that it thought it detected a bot. I had to delete the iOS app version of AVG to proceed to use Ticketmaster (after rebooting). I cannot find settings on the macOS version of AVG to allow use of Ticketmaster. Any advice for either iOS or macOS situations? Thanks much.
Hi David,
