Trial box won't go away
Hello Joyce,
I understand the inconvenience. Please provide the screenshot [http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot] of the box to check and assist further.
Hello Joyce,
Thank you for providing the screenshot. I see that AVG free traces are installed on your PC. Please follow the steps in this article http://support.avg.com/SupportArticleView?urlname=How-to-troubleshoot-issues-after-upgrade-to-the-latest-AVG-antivirus-product to reinstall AVG Internet Security by running AVG Remover and AVG Clear tool.
Note: First run AVG Clear tool and then Remover tool.
The internet security trial period is up, but the box won't go away. I can't scan my computer with the free AVG due to this box. How do I get rid of it. I cleared AVG and re-installed it but the box came right back.
Any suggestion on how to get rid of it.  Thanks in advance to all that reply.
Hello Joyce,
Hello Joyce,
