Trying to go from free to subscibed version of android clean and it will not accept the invite code. Have downloaded from the email recieved links and tried to activate but says does not accept code or code error
I apologize for any inconvenience caused. It seems like you're having trouble with the VPN setup. Sometimes, issues can arise when using certain apps like Instagram Modded Version (https://instanderlive.com), as they might interfere with VPN settings or internet connectivity. In this case, I request you to contact our mobile support team. Please click on the following link (Contact AVG Support - AVG Phone Number, and Chat Support), fill out your details, select Android, then choose the name of the AVG program installed on your mobile. In the description, explain your issue in detail, and finally click on the Email option. The AVG mobile team will respond via email with a resolution.
Best regards,
hello Alok
I now have my emails back and working. Removed ALL Avg software and it came back. Now have reinstalled all the software and back to square one with the Android Cleaner. AS I said can not log in and can not accept invitation code so in essence it is useless as will run out of trial in a few weeks. I can not log in with the LOGIN from the 3 little bars and it will accept the invitation code. Login says "Unable to connect to server please make sure you have an internet connection" Yet I can log in from the my account screen straight away.
Hello Robert,
I understand the inconvenience caused, let's work together to fix this issue. You can use AVG MyAccount credential to activate your AVG Antivirus on your Android Phone, please open AVG Antivirus Free on your phone > Tap on drawer (3 lines) on top-left of the app > Select AVG Account > Enter your My Account email address and password. Your application will get activated automatically.
Best regards,
Best regards,
Hello Robert,
Best regards,
hello Alok
Thanks Alok
The issue is with Andriod Clean not the anti virus which was sorted as you mentioned.
The clean does not allow when I log in or from an invite …have removed and reinstalled several times but no progress
You're welcome Robert, and thank you for the more information.
Please let me know which version of AVG Cleaner you have installed on your Mobile also let me know what exactly happened when you try to login in AVG Cleaner (is there any error message). If error message, then please share a screenshot of the error message to assist you further. You can click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Best regards,
